S Allen 0 Posted February 18, 2015 (edited) Hi, I am using VW 2015 and have set up some Renderworks styles to use but am stumped by the appearance of perspective lines on the final render. When creating the style I have opted to apply edges in the edit Renderworks Style dialog box, I have checked realistic not artistic. Can't figure out how to get rid of the extra lines that almost look like an X-ray line as they show the inside of a shape - any help appreciated! I would post a screenshot but can't figure out how to do that either. Edited February 18, 2015 by S Allen Quote Share this post Link to post
michaelk 512 Posted February 19, 2015 A screenshot would be helpful. Click on Switch to Full Reply Screen at the bottom of this page. Then click the File Manager Link. It will explain itself from there. MK Quote Share this post Link to post
S Allen 0 Posted February 20, 2015 Hi, sorry I can't seem to upload a file despite going through those steps - nothing shows although I added a jpg file. Quote Share this post Link to post
Benson Shaw 579 Posted February 20, 2015 It's a bit convoluted. Did you click the Done Adding Files? The steps to add a file: •Click the blue File Manager link. •Click Choose File, browse to the intended file and click to highlight it •Click Add File and wait until file name appears in the top of the box. •Click Done Adding Files •Click Submit Quote Share this post Link to post
S Allen 0 Posted February 22, 2015 Yes, did all those things and it comes up saying 0 files. Does it not recognize jpg files? Quote Share this post Link to post
Benson Shaw 579 Posted February 22, 2015 Sorry it's not working. Keep trying. File manager recognizes jpg, png, vwx, pdf. Not sure about other extensions. But File Manager does have a file size limit of 2MB. If the upload is too big, you get no file in your post. Sometimes there is quite a lag between the Add File click and the file populating the uploaded list. After you click Submit and the screen returns to your post in the forum (more lag), your post will show the file as a link (blue text), but not as an image. Showing the image requires a few more steps. Hope you get it to work. -B Quote Share this post Link to post
PVA - Jim 2,391 Posted February 23, 2015 S Allen; Email the images to tech@vectorworks.net and I can have a look/post them here for others to see as well. Please include a link to this thread. Quote Share this post Link to post
PVA - Jim 2,391 Posted February 25, 2015 Images [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=11844&filename=sallen1.jpg[/img] [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=11843&filename=sallen2.jpg[/img] Quote Share this post Link to post
PVA - Jim 2,391 Posted February 25, 2015 You mentioned in your email it didn't happen all the time, if you restart the machine or just Vectorworks then re-render, do they still appear the same or do they sort of vary from render to render? Quote Share this post Link to post
zoomer 1,090 Posted February 25, 2015 I had that too. It's just one part, parts of it hidden by other geometry. Also I have physically non existing or selectable parts that are able to darken a camera view. It can only be rendered when that Layer contending that ghost part is deactivated. Quote Share this post Link to post
S Allen 0 Posted February 25, 2015 It didn't happen initially with this particular file then for no obvious reason when I went to render the drawing again the lines were there, then once there they don't go away. Restarting etc doesn't make any difference. Quote Share this post Link to post
S Allen 0 Posted February 25, 2015 Just to point out in the second screen shot I was just showing how those lines don't show with the isometric view so I was wondering if it is somehow connected to the render works camera?? Quote Share this post Link to post
zoomer 1,090 Posted March 2, 2015 (edited) Cameras driving me nuts anyway The strange lines in Perspectives seem to occur in all Camera Views where Camera Angle (from Top View) is something like 0°, 180°, 270°, ... It seems ok if the Cam angle is something else or other than rectangular. Edit : No, it has to be at least 2° from rectangular !!! I think not ok is that Saved Views must not have the same Name as Cameras (!?) And not ok that cameras are no more working by double clicking the cam if there was saved a Save View from a Camera View. (You have to force Cam View by Edit > Show Cam View) Edited March 2, 2015 by zoomer Quote Share this post Link to post
S Allen 0 Posted March 2, 2015 Thanks for that info - I changed the camera angle to 95° and the lines went away! Seems like an annoying "feature" of the camera. I had also wondered why the double click didn't always work so you have cleared that up for me as well. Quote Share this post Link to post
zoomer 1,090 Posted March 3, 2015 But still not easy to convince the client that he can't have his one point perspective Ghost Lines or other Perspective - choose one ! Quote Share this post Link to post
AlanW 527 Posted April 4, 2015 (edited) Hi, Could you post the VW file as I run up views of a renderworks camera and no lines. Edited April 4, 2015 by Alan Woodwell Quote Share this post Link to post
zoomer 1,090 Posted September 29, 2015 Can't figure out how to get rid of the extra lines that almost look like an X-ray line as they show the inside of a shape Can anyone confirm that this was fixed for 2016 ? I mean the Ghost Lines that appeared in front of objects when an RW Style was set to use Lines, and a Central (or 1-Point) Perspective was used. (Camera perpendicular to geometry) I have set a camera to be perpendicular to geometry and don't see problems. But could be that there may be objects needed that start behind the camera to reproduce that problem. Quote Share this post Link to post
