Clive Abben Posted February 15, 2015 Share Posted February 15, 2015 I have been following Jonathan Pickups recent posts about walls. I am in the landmark workspace but when I go to landmark-architectural, I cant find the fit walls to objects command? Quote Link to comment
Benson Shaw Posted February 15, 2015 Share Posted February 15, 2015 (edited) Don't know if this helps, but this is US version 2015 Landmark workspace (Mac OS): -B Edited February 15, 2015 by Benson Shaw Quote Link to comment
Clive Abben Posted February 15, 2015 Author Share Posted February 15, 2015 Thanks for that, I have the same drop down menu, but no Fit Walls to Objects! Quote Link to comment
Benson Shaw Posted February 15, 2015 Share Posted February 15, 2015 Clive - Another thing to try - Restart the system? Also, did you check the Workspace editor? Is the Fit to Walls command in your Tools Menu>Workspaces>Edit Current Workspace? Should be in the left hand side of the edit window in the Architect section. If you find it there, drag it into the Landmark>Architectural section in the right hand side. Is it possible that you or others move it to a different area of the Landmark Menu? Or to a different menu, eg the Model menu or the Tools Menu. It might be worth opening a new drawing and looking in all of them If it's not in the left side, then better contact tech. HTH -B Quote Link to comment
Benson Shaw Posted February 15, 2015 Share Posted February 15, 2015 Also, another thread talks about problems with some security software disabling parts of VWX plugins. Might related. Reinstall vwx was solution: https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=207791#Post207791 -B Quote Link to comment
Clive Abben Posted February 16, 2015 Author Share Posted February 16, 2015 Benson, I went through the workspace editor and it was there. It is now in the Architectural section and works well! thanks for that Quote Link to comment
