Scalability of .pdf output
We use Adobe Distiller to output .pdf files for email transfer. I just found out that the output prints incorrectly - about 5% too small. I can work around this by setting print setup scaling to 106%, but I wonder if you are aware of this problem, and if you know anything else to do about it.
I compared a printout directly from VectorWorks, which scales correctly, to a printout from the .pdf file using Adobe Acrobat. The Acrobat file was 5% too small in both directions.
VW 10.0.1
WinXP
HP 4MV
