acdeslx Posted February 5, 2015 Share Posted February 5, 2015 (edited) Hi all. Is it possible to create a label legend with some of the labels in different classes so that I can turn it on or off at will by selecting classes? Essentially, I want to have fixture data on the drawing but only have some of it displayed depending on which class is selected. I tried going into the manager, editing the layout and changing the text to the class I want but it still shows up on the drawing as long as that entire symbol is displayed. Using VW2012... *** UPDATE *** I just created a Viewport to make the different versions of my plot to print and if I turn off the class in the Viewport than that section of the label vanishes -- which is what I want. However, it still doesn't explain why it doesn't work in the actual drawing layer. Thanks. Dave Edited February 5, 2015 by acdeslx Quote Link to comment
JBenghiat Posted February 5, 2015 Share Posted February 5, 2015 This should work as you described. After editing the label legend, you need to refresh any existing Lighting Devices in order for them to pull class information from the legend definition. -Josh Quote Link to comment
