drmdzh Posted January 19, 2015 Share Posted January 19, 2015 I have a couple of instruments on a FoH batten and just trying to turn them on! I've done the right-click "Turn on", got a focus point set etc etc. Nothing seems to work. This problem seems document specific as I created a blank document and tried everything and the lights work fine. So there is some setting somewhere in my document that is not allowing the lights to work. Any ideas? I have attached three images. One of a test document to show I know how to hang a light and turn it on :-) Works fie. And two of the actual file I'm working on, a wireframe one showing the positions and a Fast renderworks one, basically showing darkness. Thanks. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted January 20, 2015 Vectorworks, Inc Employee Share Posted January 20, 2015 Try replacing the instrument symbol and the default instrument texture in the problem document with resources from a known good document. Quote Link to comment
drmdzh Posted January 20, 2015 Author Share Posted January 20, 2015 How do I replace the default instrument texture? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted January 20, 2015 Vectorworks, Inc Employee Share Posted January 20, 2015 This video goes over creating a custom lighting device from scratch, I believe it also covers the default lighting texture and its application: http://www.vectorworks.net/getting-started-guides/spotlight/Gsg-2015-s09-custom-lighting-instrument Should be around 7:25ish. Quote Link to comment
drmdzh Posted January 20, 2015 Author Share Posted January 20, 2015 Thank you very much I will check it out. Quote Link to comment
mjm Posted January 20, 2015 Share Posted January 20, 2015 man how'd you get that version of VW! I thought it still under wraps! Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted January 20, 2015 Vectorworks, Inc Employee Share Posted January 20, 2015 Vectorworks 20,014, now with phase-inverted crystalline-lattice processing and empathic mood-sense wall styles that adapt to the emotional state and visual acuity of up to 8 viewers at once. Quote Link to comment
drmdzh Posted January 20, 2015 Author Share Posted January 20, 2015 I can't seem to edit the symbol in order to set the default instrument texture. If I right click I get all the lighting device options, but in the render tab in OIP it says Cannot Apply Texture to Object. Also, only the ETC Source 4s and Source 4 PARs are not working, other instruments seem to work OK. And the Source 4s work fine in the test document, so it has something to do with importing them into the current doc. Quote Link to comment
JBenghiat Posted January 20, 2015 Share Posted January 20, 2015 You can't access the symbol directly from the lighting device -- you need to modify it from the resource browser. The first thing I would try is, with your problem drawing active, browse to {VW App}/Libraries/Defaults/Lighting Instrument - Symbols/Instrument Symbols Locate the lighting instrument texture, right-click, and choose "import". When prompted, choose to replace the resource in your file. If that doesn't fix the issue, and you are using the symbols that shipped with VW, you can do the same with the S4 body symbol in the library file. If not, find the symbol in your resource browser, with the file set to Home. HTH, Josh Quote Link to comment
drmdzh Posted January 20, 2015 Author Share Posted January 20, 2015 OK< thank you. I had to delete all of the instrument symbols in my current document resource browser and then Import them from the Default VW library. Replacing when prompted did not work for some reason (I had tried that before actually.) Thank you very much, the lights are on now! No idea what I did to get into that situation. Quote Link to comment
