Wall connections
It does normally. Were these walls drawn out with the tool or copy/pasted/duplicated/moved from other sources? If Auto-Join walls is enabled, you shouldnt need to join walls or components of the same wall style. If they are different wall styles, you would need to do it manually if Vectorworks wasnt able to guess at what was wanted.
And those thin lines will disappear when using the component join tool ?
And these will not disappear if you use the normal wall join tools and
manually joining the walls ?
What do you mean by custom walls ?
Just copy a wall style and than edit or add components or is it something
special ?
  • 7 years later...
