In earlier versions of Vectorworks (maybe 2008), when you switched the leader from one side of a callout to the other side, it would change from coming off of the text block at the upper left to the lower right, or vice versa, as expected (where we read from upper left to lower right). In more recent versions, through 2014, it didn't do this automatically, such that it was always necessary to change the Vertical Position from Top to Bottom, or vice versa. An extra step. Now, in Vectorworks 2015, Horizontal Text Alignment has been added, and it's also necessary to set that from Left to Right, or vice versa, every time the leader is changed from one side to the other. Two extra steps.
Please make it like it used to be, so that the leader automatically comes off the opposite corner of the text when a leader is switched, and so that the left vs right horizontal alignment automatically switches!!
willofmaine
VWIS018
1 answer to this question
