jb.trystram Posted December 28, 2014 Share Posted December 28, 2014 I made a 2D path PIO and as i wanted the path to be edited directly with the reshape tool or by double click i make the PIO events enabled and write all necessary to make it working: begin vsoGetEventInfo(theEvent, theButton); CASE theEvent OF {User has single-clicked the object's icon. } 5: ok := SetObjPropCharVS(3, Chr(3)); 3: BEGIN { ... the rest of the script} and it works fine. But by all other Pio that use Controlpoint have them not visible anymore. even the built-in one like callout tool. I'm not sure it come from my path object. I tried before to use CP and to hyde them on purpose but i didn't get it. it looks like i really get it now and that's very bad. Do i switch a VW behavior? Thanks for help VW designer 2014 mac Quote Link to comment
jb.trystram Posted December 28, 2014 Author Share Posted December 28, 2014 Hi, Sorry for the question. I found the answer and i am not proud of it. I just had interactiv scalling off !?! but i didn't remember to switch it off. and and restart VW. maybe it should be automatically being set on start? Quote Link to comment
JBenghiat Posted December 29, 2014 Share Posted December 29, 2014 I may be misunderstanding your question, but changing interactive scaling shouldn't require a restart. It is just a mode of the selection tool (like changing the circle tool from radius to diameter) and the setting should stick between Vectorworks sessions. The mode can toggle with the U key (as with any mode), so perhaps this is how it turned off for you. You should get a warning, though. -Josh Quote Link to comment
