connered
Add Object from Library with Python
Hey,
I`m new to Vector Works and try to write a script to place objects from Library files to the scene . Can someone give me a start point for that ?
Thanks
Here's my base functions that load up a symbol in the folder inside my plugins user folder called "JRSPlugins/JRSPythonProjectsLinked/VWXSymbols"
I have a gist of this code here: https://gist.github.com/justinmilo/d85a048cb1ec4ce54270#file-jsbase-py
ef JRSymbol(name, x, y, rotation):
if not symbolExists(name):
importSymbol(name)
vs.Symbol(name, x, y, rotation)
return vs.LNewObj()
def importSymbol(id):
aListID = 1
objectType = 16 #Symbol Index
folderIndex = -2 # Plug-In Data Folder (negative means user folder)
aListID, numOfItems = vs.BuildResourceList( objectType , folderIndex, "JRSPlugins/JRSPythonProjectsLinked/VWXSymbols")
aString = ""
for i in range(0, numOfItems):
#myInt = vs.InsertImagePopupResource (dialog1, 4, aListID, i)
name = vs.GetNameFromResourceList (aListID, i)
if name == id:
vs.ImportResourceToCurrentFile(aListID, i)
def symbolExists (id):
folderIndex = 0 # Current Document
aListID, numOfItems = vs.BuildResourceList( objectType , folderIndex, "")
if name == id:
return True
return False
def Symbol2D3D(SymString, X, Y, Z, Xr, Yr, Zr):
JRSymbol (SymString, X, Y, Xr)
vs.Move3DObj(vs.LNewObj(), 0, 0, Z)# to move an individual
Edited by Justin Smith
i try to use your source - where do you call the Symbol3D or Symbol2D3D
by direct call i get an error "Error: Statement must follow creation of a 3D object."
