fkfoster Posted December 23, 2014 Share Posted December 23, 2014 when I try to use the publish command VW is crashing. For example in the publish dialog box I want to print multiple sheet layers. I change from PDF to print in the "Add new item as" drop down menu, VW crashes every time. I like this tool but is getting very frustrating. Also I have noticed that my print dialog boxes are running very slow in VW 15 compared to VW 14. I have change anything on my system. I am not upgrading to Yosemite because it doesn't support any of my printers. Any thoughts? Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted December 23, 2014 Vectorworks, Inc Employee Share Posted December 23, 2014 Does this happen in any document? If you create a new doc, add a few test sheets and try it, do you see the same slowness and crashing? Did this always happen in 2015 for you or did it start suddenly? Quote Link to comment
Ride Posted December 24, 2014 Share Posted December 24, 2014 (edited) I have the same problem, though it's not consistent. Sometimes it works, sometimes it doesn't. If I can get a repeatable condition I'll post back, but just wanted to add my name to the list for this bug. VW2015 SP1 macbook pro 2.6GHz, i7 Edited December 24, 2014 by Ride Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted December 24, 2014 Vectorworks, Inc Employee Share Posted December 24, 2014 Does it always happen when publishing to the same location? is it across a network or local that you are publishing to? Quote Link to comment
Ride Posted December 25, 2014 Share Posted December 25, 2014 When it happens for me, I don't get far enough to select a location. And no network... Quote Link to comment
Drake Posted December 30, 2014 Share Posted December 30, 2014 This is a big problem for me as well. I suspect it has something to do with using my legacy files (VW 2008) as this has caused a lot of headaches in other respects. I had to publish to PDF and then print the PDF (not optimal). Quote Link to comment
fkfoster Posted January 22, 2015 Author Share Posted January 22, 2015 I am having the same problem. It has happen from the start of installing VW 15. We are not upgrading to Yosemite as well due to not supporting current printers. I also noticed just the print dialog box seems to be very slow with this version. I just opened a blank drawing & created 2 sheet layers. I exported to PDF with no problem or lag time. I would say 99% of my files are created from a template made a few versions back. I am think that maybe if I copy all my template info into a new VW 15 file it will solve most of the problems. I am going to do a test on that. Quote Link to comment
RickS - Lab 8 Posted June 25, 2015 Share Posted June 25, 2015 Also having a similar issue since upgrading to 2015. Happens with files on local drive or on network. Only happens when using the "Print" option through the "Publish" command. We typically "Print" to the Adobe PDF print driver. When we "Publish" and use the PDF setting it works fine. When we print individual sheets through the standard print option it works fine. Seems to have gotten progressively worse which is odd??? Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted June 25, 2015 Vectorworks, Inc Employee Share Posted June 25, 2015 Also having a similar issue since upgrading to 2015. Happens with files on local drive or on network. Only happens when using the "Print" option through the "Publish" command. We typically "Print" to the Adobe PDF print driver. When we "Publish" and use the PDF setting it works fine. When we print individual sheets through the standard print option it works fine. Seems to have gotten progressively worse which is odd??? Does this happen if you perform a print via publish from a new document, not created from a template? (Just place a few shapes in the page area to test printing) Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted June 25, 2015 Vectorworks, Inc Employee Share Posted June 25, 2015 If it does NOT happen in new files, this utility can sometimes correct this issue in files where it does occur: http://kbase.vectorworks.net/questions/509/Reset+Document+Print+Settings Quote Link to comment
RickS - Lab 8 Posted June 25, 2015 Share Posted June 25, 2015 Seems ok with a new file. It is somewhat random. Some files the Publish works fine, others it crashes. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted June 25, 2015 Vectorworks, Inc Employee Share Posted June 25, 2015 Try that print reset script, let me know the results please. Quote Link to comment
RickS - Lab 8 Posted June 25, 2015 Share Posted June 25, 2015 Will try the utility on one of the problematic files. Quote Link to comment
RickS - Lab 8 Posted June 25, 2015 Share Posted June 25, 2015 Script seemed to work on the file that was giving me issues. I'm assuming it would need to be run on each file that has problems? Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted June 25, 2015 Vectorworks, Inc Employee Share Posted June 25, 2015 (edited) Yes, its file specific. This corrects issues related to printing, where the file gets stuck to an old "default" printer that no longer exists. The issue should already be fixed as of SP2 or SP3 I think, but any files that still have the problem would need this script run on them manually. It also fixes a bunch of other "housekeeping" issues in files that have been carried from version to version regarding printing, we use it frequently in support. Also helps when you get a sheet layer that refuses to give up its page size or a specific file that wont let you print current view. Edited June 25, 2015 by JimW Quote Link to comment
