P Retondo
VW 10.0.1 wall join tool bug
I experienced joining two walls where the join was not performed. The wall that should have been extended to a "T" join in "capped join" mode remained the same length on screen, but the info palette and its handles show it to be the correct length. If I use the "remove wall breaks" tool, the extended wall appears at it should had the original join gone correctly. This glitch apparently has to do with an adjacent wall not involved in the join, which overlaps the wall to be extended. Once I clear the other wall away, the join proceeds correctly. I can send you a file which exhibits this bug.
Try turning off Enabled Connect Wall Join Mode (last mode in the 2d selection tool Mode Bar), before joining the wall.
Email one of the files to me, just to make sure I understand what you are saying correctly.
