binubinu Posted December 16, 2014 Share Posted December 16, 2014 I have two design layers, each with a different scale, the two layers for some reason do not show on top of each other (even when the visibility is ON). Each layer when made active is visible but are not visible on top of each other. They are NOT on 'active only' mode but are acting like they are. What might I be doing wrong? As a test I created two different design layers with the same scale and the contents are visible. Appreciate any help. - b Vectorworks 2015/ MAC user Quote Link to comment
Phil hunt Posted December 16, 2014 Share Posted December 16, 2014 I may be wrong but I think they both have to be the same scale for the 2 layers to show its only when you create viewpoints you can create different Scales Quote Link to comment
binubinu Posted December 16, 2014 Author Share Posted December 16, 2014 I figured it out! Under View > Unified View has to be ON. Quote Link to comment
Arkithector Posted February 4, 2021 Share Posted February 4, 2021 @binubinu you are the best Quote Link to comment
