Possible Problematic Column Objects & Classing problems
I have come across something which seems like anomalous behavior regarding the Column objects. [img:left] Column-class issue[/img]
The columns seem to handle lighting so radically differently depending on classing and/or fill color, not to mention the fact that complementary colors of light on a surface are as if the source was off, that I wonder if there is a problem with the Column object itself.
If this is expected behavior of classing, fill color and lights, ok then.
I have attached a demo file & I believe the problem exists across both 2014 & 2015.
Edited by mjm
