marshigh Posted November 27, 2014 Share Posted November 27, 2014 Is there any way to calculate for the volume in a wall (or all walls in a document) minus the volume that the studs take up? This would be useful for calculating insulation on a take off. Quote Link to comment
Guest Wes Gardner Posted December 1, 2014 Share Posted December 1, 2014 You can run the standard Wall Area report from Tools > Reports > VA Create Schedule > Wall Area that will give you the gross and net areas of the entire wall. You can also add and use the call =ComponentArea(xx) where the xx is the number of any one of the individual components. Wes Quote Link to comment
marshigh Posted December 4, 2014 Author Share Posted December 4, 2014 wouldn't that just give me the "area" (not the volume) of each component? Quote Link to comment
