VW2015 crash
I've been hitting the eyedropper tool pretty heavily with no crashes.
I've only seen crashes when:
1. Hitting Undo while editing a worksheet
2. Doing a Convert Copy to Lines on a big mesh object downloaded from a 3d library site.
I've had one or two other crashes, but no evident cause. In both cases I had at least 3 large VW documents open.
mk
  • 2 weeks later...
I've been getting the same problems.
The eyedropper tool only works the first time when starting up Vectorworks, then it's crash the second time I use it.
I've mostly used the eyedropper tool inside a symbol.
Both clicking on the icon or using a hotkey will result in a crash.
I've been picking up fill, pen, and text attributes mostly.
After using the dimension tool inside a symbol, when I try to use the eyedropper tool to grab the attributes of other dimension lines, the programs crashes.
I can replicate this consistently following the steps above.
The work around is I just hit save before using the eyedropper, quit the program, then open it again and use the eyedropper once. Every time after the first will crash.
  • 1 month later...
  • 2 weeks later...
  • 2 months later...
