domer1322 Posted November 17, 2014 Share Posted November 17, 2014 has anyone noticed the plant scaling using the OIP doesn't work ? .... or am I the only one with the problem ? In sum, if you asymetrically scale an image prop tree to be half height (but same width) it will render correctly in Open GL but if you switch render modes to RW then it will appear full height. It seems the problem is a little different on the Mac OS than it is on the Windows OS, but either way there is a problem. Someone please confirm this, so I can stop trying to make my version work correctly. Quote Link to comment
