domer1322 Posted November 11, 2014 Share Posted November 11, 2014 I think I've noticed a bug and wonder if someone can confirm this .... import an image prop plant, like juniperis Communis and try the OIP asymmetric scaling. What I've found is that the new proportions scale correctly when viewing in OpenGL, but when you switch to Final RW, the tree does not scale correctly. This is annoying, since the same plant will be differently sized depending upon viewing in Open GL or RW. Can anyone confirm this, or is it just my problem ? This occurs in VW 2015 using the Mac OS. Quote Link to comment
domer1322 Posted November 11, 2014 Author Share Posted November 11, 2014 a little more investigation led to this discovery .... the asymmetrical scaling doesn't work when you take an image prop and turn it into a 3D hybrid symbol by adding a 2D symbol. Even something as simple as a circle for the 2D symbol will cause the scaling to work oddly. Quote Link to comment
