grant_PD
Text Options on Right Click when Text is active
I'd like to have the right click be contextual to the tool being used. In addition to the user customizable right click, engaging the text tool and then right clicking with a text box selected should bring up things like: text size, formatting, style (think MS Office).
I could see this being very useful for several tools.
9 answers to this question
Would this be triggered ONLY if the right-click did not occur over a piece of geometry that had its own contextual menu items? Or would it simply add to the contextual list? The context being both the object that was right-clicked on as well as the currently active tool?
Good questions. Let's say that I hovered over the text box, I guess I would want the contextual menu to come up then. I mean, why else would I hover over the text box?
VW suffers greatly from OverPalleteReliance. There are too many places I need to go to in order to change things, enter info. Those 1/2 second mouse moves add up over the day, slowing down the work and killing the wrist.
Would this be better done as a new UI element rather than simply adding to the existing contextual right-click menu? A sort of pop-out settings menu or set of buttons similar to the floating data bar? With a user-controllable timer for how long the hover needed to be to pop up the options, as can be set for smartcursor cues?
Yes. Have it pop out the tool options as well. Because the U,I,O keys work well, but tool options change for each tool, so you still have to look UP to see what you're doing.
The dimension tools could use that option also, both the right click option, and tho be able to edit text font, size, etc in the object info palette, rather than just from the pull down menu.
Taking the idea further...
as a default any object I hover over and right click I should be able to get a class and layer dropdown, or at least a "assign to class/layer" which opens up a dialog to do so.
+ additional, hover over an element brings (by the floating data bar)
- element type
- class
- layer
