ga Posted January 22, 2003 Share Posted January 22, 2003 We need to export large numbers of files to our consultants as Autocad drawings. The problem is that our titleblocks which are drawn using solid white backgrounds to obscure unnecessary parts of the drawing are not coming through as solid. they just disappear making the resulting dwg illegible for our consultants. we are on VW 9.5.3 and OS X.2.3 I know that solids are not exported properly but has anyone got any suggestions. much appreciated Quote Link to comment
Guest Posted January 23, 2003 Share Posted January 23, 2003 While 2d solids are not supported in VW 9.x in the export process, VW 10 does support solid fill export. In VW 9, there really isn't a good way to work around this. If this is something that is mission critical to your work load, you may want to think about upgrading to VW 10. Quote Link to comment
