MikeB Posted January 21, 2003 Share Posted January 21, 2003 We stumbled upon a strange little bug today, if you try export a polygon (or polyline) with a solid fill but no line weight, it will not export (or import, I'm not sure where the object accually disappears) Is this a bug, or is it a limitation of the import/export engine? Thanks Quote Link to comment
P Retondo Posted January 22, 2003 Share Posted January 22, 2003 Mike, Since fills don't translate into ACAD, is it possible the object is there but you just can't see it because of the 0 line thickness? Quote Link to comment
MikeB Posted January 22, 2003 Author Share Posted January 22, 2003 I thought of that, so I reimported my DWG into VW and the objects really aren't there. Quote Link to comment
ionw Posted January 22, 2003 Share Posted January 22, 2003 Miike, I had this same problem in 9.x.x with round walls being used in the same way by one of our designers. I think at the time we simply turned on the lines so our consultant could at least see the paths they were representing. I guess now that VW 10 supports hatches and fills in its import/export I would try to set the pen color/pattern to match the fill, and make it a very fine line. just a thought. Quote Link to comment
Guest Posted January 22, 2003 Share Posted January 22, 2003 Mike, Are you using VW 10 or 9? If you are using VW 10, make sure you have Export 2d fills checkmarked. A 2d object with no pen and a solid fill will export just as you see it in VW when opened in AutoCad 2k. VW 9, this behavior is represented as 2d fills are not exported. [ 01-22-2003, 10:24 AM: Message edited by: Katie ] Quote Link to comment
