Multiple extrudes are troublesome and outdated. Please rebuild the multiple extrude command so it creates lofted solids (ie. the equivalent to using the NURBS loft command and checking the create solid checkbox). Its time that the existing multiple extrude code was banished to the garbage.
Ultimately it should be more like the C4D loft object, where you can edit it and drag the profiles in relation to each other.
Kevin McAllister
(See this thread and many others - https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=203999#Post203999)
Kevin
3 answers to this question
