Tn_Pink Posted October 17, 2014 Share Posted October 17, 2014 Hello, What function in vectorscript do I need to get the current 3D coordinate points of a moved, revised or expanded object like a nurbs curve? Thanks in advance. Quote Link to comment
Hippocode Posted October 17, 2014 Share Posted October 17, 2014 Hello, What function in vectorscript do I need to get the current 3D coordinate points of a moved, revised or expanded object like a nurbs curve? Thanks in advance. Do you want the 3D location of the nurbs ? Or the position of vertexes of the nurbs ? http://developer.vectorworks.net/index.php/VS:GetSymLoc3D Gives the current position for symbols and objects. http://developer.vectorworks.net/index.php/VS:NurbsGetPt3D This will get you the location of each point within a nurbs. You will need to use some other functions to define index 1 and 2. What I mostly do is convert it to a 3D polyline because it's easier to work with. Quote Link to comment
Tn_Pink Posted October 20, 2014 Author Share Posted October 20, 2014 (edited) I got it and applied already (VS:NurbsGetPt3D). Thank you so much. Edited October 20, 2014 by Tn_Pink Quote Link to comment
