ramooo Posted October 16, 2014 Share Posted October 16, 2014 I am wondering if it is possible to work with virtual wall components. I am trying to do that in order to create auto-bounded slabs in a way that allows to have an space complete open to the outside in one of it sides. The problem I have found is that when I create empty components (as if it were a virtual wall) the component only shows invisible if the overall wall attributes are set to none, but with that configuration the whole wall became invisible in 3d. Any ideas? Quote Link to comment
bcd Posted October 16, 2014 Share Posted October 16, 2014 Why not give it the same texture as the slab edge? Quote Link to comment
ramooo Posted October 17, 2014 Author Share Posted October 17, 2014 I did that already. The virtual component is not for the open side of the slab but for the other walls. I need the top component of the slab to cover the wall I am using as front cap for the open side of the slab. Those settings work great in plan and section views, but in 3d the whole walls appears as phantoms. I only need the virtual component of the wall to be invisible. Quote Link to comment
ramooo Posted October 17, 2014 Author Share Posted October 17, 2014 This is the file: Quote Link to comment
VincentCuclair Posted October 17, 2014 Share Posted October 17, 2014 (edited) Why not put the virtual component in it's own special class and hide the class when needed? Edited October 17, 2014 by Vincent C Quote Link to comment
VincentCuclair Posted October 17, 2014 Share Posted October 17, 2014 Have you tried the clip tool on slabs? It's not as intuitive as auto bounding but perhaps a little easier to apply and it is editable to a degree. Quote Link to comment
ramooo Posted October 17, 2014 Author Share Posted October 17, 2014 Thanks a lot Vincent! Hiding it´s own class did the job. I prefer to use the clip tool only in interior walls. Quote Link to comment
ramooo Posted October 17, 2014 Author Share Posted October 17, 2014 Well, actually it is not working 100% Now I am missing the end cap line in plan view when I hide the component. It happens both if the wall caps attributes are set to wall line or component line. :crazy: Quote Link to comment
bcd Posted October 17, 2014 Share Posted October 17, 2014 Have you tried a wall with 1mm height? Quote Link to comment
ramooo Posted October 17, 2014 Author Share Posted October 17, 2014 Nop, because I need that wall with almost all the height of the slab. Quote Link to comment
ramooo Posted October 17, 2014 Author Share Posted October 17, 2014 Uffffff!!!! the situation is even more complicated: When the class of the "virtual component" is off, the wall end caps produce a white mask in one of the side walls. It seems like is not going to work... How do you manage to have auto-join slabs when designing spaces with one or more open sides? Please help Quote Link to comment
Joe-SA Posted October 28, 2014 Share Posted October 28, 2014 This is not the help you are looking for but my reaction is to say that I gave up on auto-bound slabs about the first or second time that I used them. All it takes is one edit to one wall of the perimeter to turn the entire slab into manually bound. We found this to be inevitable with every job. Now we just create them by drawing the perimeter or purposefully unbinding them right after they are created with the walls. I hope auto binding to walls is not the hold up with Roof Components because if it functions like the slab does we are more likely to stick with manually binding them anyway. Joe Quote Link to comment
