Text default
I am a new user to VW and I am having a problem with the text default. When I select the text tool and type a text and enter it there is not text visable. I can change the text to colored and it showes up. Whin I try to change the text defalt to black it will not change and keeps giving me white text . Anyone have any sugestions.
Thanks
Make sure that nothing is selcted by clicking on a blank spot on the drawing then change the color in the atributes pallette and font, size, style in the text menue select the text tool and then your text will be what ever color you chose this also applies to other objects you draw (line ,polygon, etc) if you change the atributes with an object selected then only that object is changed or change attributes with nothing selected and all objects created after will take on the new settings till you change again
