Benson Shaw Posted October 14, 2014 Share Posted October 14, 2014 I saw a note in General forum that file names with forward and back slashes are causing some problems. Is this related? The Publish command. In the Publish dialog, if I name the new file with a date, say 2014/01/12_MyFile.pdf The output creates nested folders, one level for each slashed entry. The new file is in the last folder with name _MyFile.pdf. Is this nesting folder arrangement intended? I could switch to underscores or other separators, but slashes worked in prior versions. -B Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 14, 2014 Vectorworks, Inc Employee Share Posted October 14, 2014 Hadn't seen that portion of the issue before, I know they corrected the main problem in file names but I do not know if this will be changed as well. I'll check and see if this is tied directly to the already submitted issue. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 24, 2014 Vectorworks, Inc Employee Share Posted October 24, 2014 This will be fixed, not sure exactly when but I would not be surprised to see it in the next patch. Quote Link to comment
Benson Shaw
-B
2 answers to this question
