jeremyb Posted October 10, 2014 Share Posted October 10, 2014 I have one doc in which plant tags are not showing, The tag line is showing but no tag content. This is both turned on and the class is set to visible. Now using VW2015 Any ideas? Quote Link to comment
jeremyb Posted October 10, 2014 Author Share Posted October 10, 2014 Confusingly some newly imported plants are now showing the plant tag labels, others not. Quote Link to comment
jeremyb Posted October 10, 2014 Author Share Posted October 10, 2014 Sorted! It turns out that the font size was not set to any number. Once set the tag labels appeared. Phew! Quote Link to comment
Benson Shaw Posted October 10, 2014 Share Posted October 10, 2014 Good sleuthing! A blank font size field? Was that default? Blank fields often cause refusal to dismiss the dialog. Sounds like a bug. I will try to reproduce. -B Quote Link to comment
Benson Shaw Posted October 12, 2014 Share Posted October 12, 2014 Well, my quick check is not much help. Place a plant w/ Place Plant tool. Accept the defaults. The plant tag is not visible (my defaults), until change OIP Tag Display from None to Left (or Right). Then the tag and text are visible. Text is assigned to the Plants-Components-Tags class which defaults to Unstyled text. Unfortunately, assigning a text style in the Class edit dialog seems to have no effect on text in the tag. When OIP Tag>Display for above plant is set to either left or right visible mode, the text size can be adjusted in the Text>Size>Set Size dialog. That dialog requires a value in the size field. Value has to be present, greater than zero and positive, or the dialog box will not dismiss. Maybe those problem tags are imported from prior versions of vwx or other software? Anyway, looks like you have it handled. -B Quote Link to comment
