jet Posted October 8, 2014 Share Posted October 8, 2014 Could anyone point me in the right direction, document or tutorial... I want to have a symbol or object that i can drop on the drawing, and it is sized based based on a few variables the user can change. for example a table, that the user can enter the length and width... VW 2015 designer series Quote Link to comment
Pat Stanford Posted October 8, 2014 Share Posted October 8, 2014 What you are looking for is a Plug-in Object (PIO). This is a special type of script that needs to be written in Vectorscript, Python or using C++ and the SDK. If you have never programmed before the learning curve can be steep. Vectorscript is based on Pascal, so if you have experience there you are a leg up. The first place to look is in the Custom section of the VW website: http://www.vectorworks.net/support/custom/ From here you can get to the language documentation and some example code. There is also example code in this forum and in the Vectorscript Sharing forum. Robert Anderson posted a basic article about Vectorscript there some time ago that would also be a good starting place. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=93218#Post93218 If you post with some additional information on what you are really trying to do (don't try to give us a "simple" version unless that is the result you really want), we can probably offer some additional guidance. Quote Link to comment
