Kevin McAllister Posted October 8, 2014 Share Posted October 8, 2014 I would like the Deform Tool to create a solid addition instead of individual generic solids when I deform an extrude that has multiple pieces to start with. See this thread for an example - https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=203480#Post203480 Kevin Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 8, 2014 Vectorworks, Inc Employee Share Posted October 8, 2014 Submitting request now. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 8, 2014 Vectorworks, Inc Employee Share Posted October 8, 2014 While on the subject, do you feel that when multiple non-connected/touching objects are extruded, they should become one extrude, or multiple separate extrudes? I have often had trouble with objects created from multiple separate objects being extruded together. Quote Link to comment
0 Kevin McAllister Posted October 8, 2014 Author Share Posted October 8, 2014 I love that multiple objects extrude to become one single extrude. I use this constantly. Did you know that its as simple as ungrouping them to make them a collection of individual extrudes? Simple example of how I would use this - table legs - so you can quickly adjust table height all at once. Kevin Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 8, 2014 Vectorworks, Inc Employee Share Posted October 8, 2014 Then I will leave it alone Quote Link to comment
0 Diamond Posted October 21, 2014 Share Posted October 21, 2014 Hi Jim, Regarding this, I have been pushing the bounds on this. I have been experimenting with a 3D symbols of a facade containing about 60,000 3D polygons. A couple of comments; 1. The deform tool converts the 3D polygons to class of the symbol, not the classes contained with the symbol or the object. For my multi class facade, I had to split it up class by class, deforming each individually. 2. Large facades are slow. Any way to have this tool support multi-processors? 3. Is there a way to have an options dialogue to select the option stated above, or use contained classes, etc? Thanks. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted October 22, 2014 Vectorworks, Inc Employee Share Posted October 22, 2014 1) I will submit a request for this shortly. 2) As far as I understand this is already going to happen, but I do not know when. The large chunk of the work was moving everything to 64bit, modernizing everything else will apparently be easier now. 3) Combining into the request for #1 Quote Link to comment
Kevin McAllister
Kevin
6 answers to this question
