BiztroBill 0 Posted October 7, 2014 Hey. I have a worksheet question. When I revise a sheet, I select the sheet border and use the OIP to enter the revision number and date with a brief description. This info displays on my title block because I included rNo, rDate, and rNote in my title block symbol. I don't have to use the "Use revision block" option in the OIP, if that matters. Works great. I created a Sheet Index on my cover sheet that lists sheet number, name and date, pulling the data from my sheet borders. Good start, but I need to add revision dates to this worksheet. Is this possible? Quote Share this post Link to post
Jonathan Pickup 212 Posted October 8, 2014 I'm sure it is possible, you have to set up the worksheet to find the current revision data from the sheet borders. Quote Share this post Link to post
BiztroBill 0 Posted October 8, 2014 Thanks, Jonathan. If this calls up sheet numbers from HFA-TBLK: =('HFA-TBLK'.'S_SheetNo_SN') then how do I get :rDate from the sheet border? And if there are multiple revisions on a sheet, which date would I get? Not sure it matters, but I embedded text items for :rNo, :rDate and :rNote in my title block symbol, rather than using the 'Use Revision Block' option. Quote Share this post Link to post
BiztroBill 0 Posted October 8, 2014 OK, I figured out a workaround. I added a column to my Sheet Index with the heading "Latest Rev No" and used this formula: =('Drawing Border - Universal'.'__lastissue') What I discovered is that 'Drawing Border - Universal' is the name of my Sheet Border object. This must be a hard-wired name generated by VW. '__lastissue' is the field that gives me the most recent issue number. There is no corresponding field for revision numbers, so I might have to use the issue number tool instead. Here is what the worksheet looks like: [img:left]https://www.dropbox.com/s/ca6uq3ssyx33f68/Screen%20Shot%202014-10-08%20at%203.07.41%20PM.png?dl=0[/img] I get @ signs for sheets that have not been revised. I don't want to get phone calls asking what the @ sign means so I changed the formula to an IF statement that returns either a space instead: =IF((('Drawing Border - Universal'.'__lastissue')='@'), ' ', 'Drawing Border - Universal'.'__lastissue') Here is what that looks like: [img:left]https://www.dropbox.com/s/3owi9p6cy2xgnqp/Screen%20Shot%202014-10-08%20at%203.18.57%20PM.png?dl=0[/img] Seems to be working. Hope this helps someone. Quote Share this post Link to post
neal-2002 7 Posted October 16, 2015 Im trying to add the last revision letter, revision date & issue dates to a worksheet schedule similar to the info you've been discussing, Ive found the following info on a Dutch VW forum which may be of use to others - DATABASE = ((R IN ['Drawing Border - Universal'])) and then the cells: Revision information: = ('Revision Date'. "Date-1) = ('Revision Date'. 'Zone 1') = ('Revision Date'. "Approved-1) = ('Revision Date'. 'Description-1) comments: = ('Issue Date'. 'Number-one') = ('Issue Date'. "Date-1) = ('Issue Date'. "Note-1) = ('Issue Date'. "Approved-1) Note that those " 1 "Here always represents the line of the revision or comment. Can anyone help me work out what the formula needs to be to get the LAST revision & revision date to work in a drawing issue worksheet? - as this only gives you the first rev or second if you change it to "2" etc.. Quote Share this post Link to post
Hippocode 13 Posted October 16, 2015 Im trying to add the last revision letter, revision date & issue dates to a worksheet schedule similar to the info you've been discussing, Ive found the following info on a Dutch VW forum which may be of use to others - DATABASE = ((R IN ['Drawing Border - Universal'])) and then the cells: Revision information: = ('Revision Date'. "Date-1) = ('Revision Date'. 'Zone 1') = ('Revision Date'. "Approved-1) = ('Revision Date'. 'Description-1) comments: = ('Issue Date'. 'Number-one') = ('Issue Date'. "Date-1) = ('Issue Date'. "Note-1) = ('Issue Date'. "Approved-1) Note that those " 1 "Here always represents the line of the revision or comment. Can anyone help me work out what the formula needs to be to get the LAST revision & revision date to work in a drawing issue worksheet? - as this only gives you the first rev or second if you change it to "2" etc.. Sadly for you, there is nowhere a field saved that holds the index of the last added revision. There is a solution for you but you would need to use a script to find the last used index by traversing the list until you find an empty one... Quote Share this post Link to post
neal-2002 7 Posted October 16, 2015 ah well - thanks for the quick response. Quote Share this post Link to post
