gester Posted October 7, 2014 Share Posted October 7, 2014 hi, i try to do the above, but all i get is some floor plan view, no trace of a section in the exported dwg. i've posted here, but can't get any feedback. i may be missing something important, but i don't know what. thx in advance, rob Quote Link to comment
gester Posted October 19, 2014 Author Share Posted October 19, 2014 i've examined the dwg export options and one possibility would be to export the sheet layer as the 2d graphics in the model space. is it the optimal solution for section sheet layer dwg export? i'd like to give the design consultants as option to use the section in the most flexible way as a dwg... rob Quote Link to comment
Gytis Posted October 22, 2014 Share Posted October 22, 2014 What settings are you using? I have success, with minor text/hatch oddities using the settings (more or less) in grab: Section VP sheet layer ends up in paper space. Quote Link to comment
gester Posted October 22, 2014 Author Share Posted October 22, 2014 well, my goal was to provide a working underlay for the design consultants, and they prefer model space. exporting to the paper space i get the actual design layers of the section viewport creation instead of the section itself, but possibly there are some settings i miss. checking the 'export viewports as 2d graphics in model space' check button in the 'sheets to include' section apparently brings the export in the direction i intend, but i'll have to check the options once more. thanks for the insight. rob Quote Link to comment
