nick lawrence
Attribute / Colour Palette
Hi all!
I am having problems with my colour palette. I seem to have lost the ability to chose different colour palettes, and when i click on the settings icon nothing happens. Really frustrating.
Does anyone know how i can get my options back?
Thanks
Nick
(VW2014, OS 10.9.5)
If you go to Tools > Workspaces and pick an alternate workspace, (if you have another available, Fundamentals users may not) does the same issue occur when you try to switch palettes?
Does the same problem occur after you reboot the machine, launch no programs other than Vectorworks and then then try changing the palette?
Yes.
I have tried all the obvious things - restarted, and tried different workspaces.
Also tried with various drawings but is seems to be a VW issue rather than a specific drawing issue....
I see a similar post on the German Forum,
+ all custom settings lost.
But he seems to be a Windows 7 User.
Edited by zoomer
Have you checked your source folder to make sure it has the palettes in it? Or maybe you are pointing to the wrong folder?
My color palettes are in the VW2015-installed location: \Applications\Vectorworks 2015\Libraries\Defaults\Color Palettes.
In case you still haven't found the answer, maybe if we go through the steps it will strike a chord. I know this sounds pedantic, but maybe your answer is in here somewhere. Just trying to help.
First check the following folder to make sure you have palettes in the right place:
You should have something like 35 .xml files there. If that's good then start a new document and click the fill color in the attribute palette. In the color selection palette, if you don't have the palette choices you want in theclick the tool button in the top right to open the Color Palettes Manager.
If you don't get the list of 35 palettes, then maybe you are pointed to the wrong location.
Then the next question would be whether you have changed the User Folders in the Preferences?
In case you're still searching....
I had a custom color palette migrating through the upgrades that was not in (Mac) Users\(me)\Library\Application Support\Vectorworks\20xx. Somehow I'd copied and pasted old color palettes in to the new version.... via templates perhaps(?) - not sure how actually since version updates are far enough apart I never seem to remember how I did things.
Anyhow, what I did this last update was find an old file (v2013 in this case) employing the color palette I wanted to bring forward and opened it in the latest version of Vectorworks, thereby updating it. I then accessed the Color Palette Manager via the attributes palette - 'Tools' button (upper right). At the top of the list of color palettes was 'Colors In Active Document'which is the palette I wanted available as a standard but didn't exist as an .xml document anywhere. To correct this I simply selected the 'New' button at the lower left of the Color Palette Manager window bringing up another dialog box asking for colors to populate the new palette. In this dialog box I typed in the name for the new palette and then selected the 'Get' button which brings up yet another dialog box for specific color inputs. Down the left side of this dialog box there is a list of other palettes from which you can import colors. I picked the palette 'Colors In Active Document' (again) which then displayed my sought after color palette on the right side of the dialog box. From there simply 'select all' (I did this by click-dragging the entire color grid displayed) and then selecting 'OK'.
This series of steps created a .xml version of my color palette placed properly in Users\(me)\Library\Application Support\Vectorworks\2015 and made my color palette available to all v15 Vectorworks files.
Now that I've done it 'properly' this time I suspect the simpler migration of the custom .xml document to the new folder will suffice for future updates.
Hopes this helps or you've found another suitable solution,
AHDesign1
