P Retondo
Trim tool broken in 10.0
The trim tool does not work properly. Place a line over a polygon, and attempt to trim away a portion. An incorrect portion is often trimmed away, and the object being trimmed can sometimes just disappear.
I've found that the trim tool is basically for lines. Use 'Clip Surface' for trimming away segments of polys....much better.
Thanks, runtime. I am pointing this out because the trim tool used to work (I'm talking about the tool, not the menu command), and doesn't anymore. I think it didn't work in version 9.5 either. It's a lot faster to trim a polygon with a line as opposed to drawing another polygon and clipping.
P -
Are you trimming an open or closed polygon?
Is it a polyGON or polyLINE?
Can you send a simple or complex example of this to me, please?
tech@nemetschek.net
attn katie
Make sure you note it's VW 10.0.1 in the email.
Katie,
In trying to recreate the problem for you, I think I discovered that it only occurs when one or both ends of the cutting line lie precisely on the boundary of the polygon to be cut. I'll send you an example.
I take that back. I just sent you a second file where the line goes beyond the polygon boundaries, and the trim tool doesn't work.
I have the files. I'll take a look at them as soon as I can.
It looks like when the line used as the trim line intersects a 90d or right angle corner on a polygon, the trim doesn't know how to split that corner and deletes the entire polygon.
This is currently being investigated as a bug.
If you are trimming at a corner of a polyline that is other than a 90d corner, the trim line must extend PAST that corner point a few pixels in order to get the trim to work.
Please don't tell me that this is actually an unkown...
I thought that the trim tool was designed to work on only certain things. I've noticed for half a year that certain things (e.g. polygons) can't be trimmed, but can be split.
VW9.5.3
