3D Polys to 2D Polys
zoomer
Yes, sort of.
Since 3D polys can exist outside of one plane, but 2D polys can't, they will just "flatten" when converted if they weren't already flat.
To convert them, select the 3D polys, use Modify > Convert > Convert to Polygons (or Convert Copy to Polygons)
This will give you a group. Ungroup it, then use Modify > Compose to combine any non-connected polylines/lines into polygons.
Thanks Jim.
I tried but I think a 2D Polygon is not really what I wanted
as it can't stay at its position in 3D :)
Leave them in 3D for now.
As I see I can draw 2D rectangles in a Front/Back/Side View
vertically - only when there is a object behind to give the
direction by the blue working plane.
For every thing else, 2D means XY plane, right ?
Thanks for the Video.
I see now,
everything works as expected in Orthogonal Views
with automatic workplane.
No option to rotate in working plane in Isometrics when no help geometry.
(2D orientation = ground plane)
But unfortunately I loose the automatic orientation mode in
Orthogonal Views when standard "3D View" mode is set to Perspektive !
Edited by zoomer
  • 2 weeks later...
