add geometry to extrusion
Pi_
Hi,
I want to add geometry to an extrusion created inside a polyline-PIO.
The geometry I want to add is read from a symbol. (I want to create custom section beams/columns)
here is part of the code, the problem is that the geomtry is copied in the 3d-part of the symbol, instead of being copied in to the extrusion, even if I use 'setparent', anybody any suggestions?:
if Pdoorsnede='symbool' then polyh:=HDuplicate(FInSymDef(GetObject(Psymbool)),0,0);
extrudeh:=ExtrudeAlongPath(ash,polyh);
if Pdoorsnede='symbool' then begin
polyh:=FInSymDef(GetObject(Psymbool));
while polyh<> NIL do begin
polyh:=NextObj(polyh);
{ h:=HDuplicate(polyh,0,0); }
h:=CreateDuplicateObject(polyh, extrudeh);
ok:=SetParent(h, extrudeh);
end;
end;
Maybe you are trying to create an extrude based on the symbol ?
In that case you need to create one surface / nurbs curve based on the geometry of that symbol and use that as profile when creating the extrude.
You can't change it afterwards.
The SetParent function can be used on layers, groups etc only for container based purposes.
The ExtrudeAlongPath command you use doesn't create one extrudeobject but a combination of multiple surfaces that form the extrude. Its not an active object you can edit later on
Edited by hippothamus
thanks,
I did it this way:
begingroup;
h:= CreateDuplicateObject(polyh,nil);
end;
endgroup;
extrudeh:=CreateCustomObjectPath('Extrude Along Path', ash, LNewObj);
next problem,
polyh2:=GetObjectHiddenLine(extrudeh,10000, True);
doesn't work on 'Extrude Along Path' (it does work on 'ExtrudeAlongPath'
