steve s Posted September 29, 2014 Share Posted September 29, 2014 I have some 2d objects on the ground plane, it seems i used to be able to leave them 2d in a 3d view and they didn't look too bad, but now as the pic shows the 2d ground plane objects are all blurry. I turned off anti aliasing in the preferences. The pink and green are 2d objects as is the parking lot lines. Is this unavoidable? Thanks Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 29, 2014 Vectorworks, Inc Employee Share Posted September 29, 2014 In a test here I did not get blurry results with 2D geometry, tested Lines, Rectangles and 2D Polygons: [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=11211&filename=2d%20polys%20and%203D%20geometry%20in%20FQRW.PNG[/img] Could you send any one of the files you see this in to tech@vectorworks.net? I can have a closer look. Quote Link to comment
steve s Posted September 30, 2014 Author Share Posted September 30, 2014 thanks Jim the file is 100MB Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 30, 2014 Vectorworks, Inc Employee Share Posted September 30, 2014 A dropbox link or using mailbigfile or another transfer service is fine. Quote Link to comment
steve s Posted September 30, 2014 Author Share Posted September 30, 2014 ok I sent a link Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 30, 2014 Vectorworks, Inc Employee Share Posted September 30, 2014 Got it appearing properly after performing a layer import. There seem to be problems with the conversions of a Roof object as well as some column structures, which you will probably see if you perform this procedure to bring your geometry into a new 2015 document: http://kbase.vectorworks.net/questions/790/Layer+Import However the odd aliasing issue was gone once I performed the Layer Import. I will see if I can track the issue down more specifically, Layer Import is a heavy big hammer of a troubleshooting step as it removes sheet layer info. [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=11219&filename=2d%20polys%20and%203D%20geometry%20in%20Fast%20RW%20test%202.PNG[/img] Quote Link to comment
Dillon Posted February 11, 2015 Share Posted February 11, 2015 I have the same problem with 2D objects in 3D views when rendered with Renderworks. OpenGL is fine. I asked tech support about this and they say it is a limitation of the software. Jim, how do you get acceptable results? this is particularly a problem with the parking space tool which only produces 2D results (the "show 3D stripe option creates super blurry lines). This is the tech support response: Renderworks is optimized for 3D geometry. The ability to see any 2D planar objects in a Renderworks render is actually a fairly recent addition. In most cases, 2D planar objects should not be used if you intend to render in a Renderworks mode. When creating 3D models, it is best to use only 3D objects. In this example, simply converting the line to 3D polygon with drastically decrease the render time and allow the object to render correctly. Our engineering team is aware of the current limitations of planar objects in Renderworks modes and is working on adding better support in the future. Thank you. -- Michael Groves Technical Support Specialist Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 11, 2015 Vectorworks, Inc Employee Share Posted February 11, 2015 Those above acceptable results are in OpenGL, specifically. Quote Link to comment
zoomer Posted February 11, 2015 Share Posted February 11, 2015 http://kbase.vectorworks.net/questions/790/Layer+Import /quote] KBase broken ? All the videos are hidden, just a link : view video >>> access denied If I try to log in I'm not accepted as an administrator Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 11, 2015 Vectorworks, Inc Employee Share Posted February 11, 2015 Link fixed! I'm the main administrator for now Quote Link to comment
zoomer Posted February 11, 2015 Share Posted February 11, 2015 (edited) Thanks ! Looks that more videos were lost as I was walking through some other articles where videos are linked only. F.e. http://kbase.vectorworks.net/questions/813/Importing+Classes+and+Layers Seems that entries with videos that are embedded work fine. Edited February 11, 2015 by zoomer Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 11, 2015 Vectorworks, Inc Employee Share Posted February 11, 2015 Yeah some of the older articles are holdovers from before we put things on Youtube. Which is a much better solution than hosting the videos directly. Most of these articles I have gone over and corrected over time, but any time you come across one, let me know and I can correct it right away. If you're in a hurry to get to a video that happens to be that way, normally you can search our YT channel for the title of that article and you'll find it right away. Quote Link to comment
