Majic Posted September 28, 2014 Share Posted September 28, 2014 So I find the Help system for 2015 is pretty good, but I can't find the PDF files for this version, which I miss. Mostly I miss being able to read through a section, "turn pages", and read all about a topic on my iPad when not connected to the Internet. Are PDFS available for 2015? Quote Link to comment
bc Posted September 28, 2014 Share Posted September 28, 2014 I believe that inside your Vectorworks folder is a folder called VWHelp. Inside that you'll find another folder called Additional Documentation. See if the various PDF's are in there... Quote Link to comment
Jonathan Pickup Posted September 28, 2014 Share Posted September 28, 2014 The new Vectorworks Help for 2015 is now web based, so that it can be kept up-to-date all the time. However, if you have a look in your application folder, VW help, you should find the folder HTML 5. This has a copy of your help, and I suggest you start with table_of_contents.htm Quote Link to comment
bc Posted September 28, 2014 Share Posted September 28, 2014 Yes, sorry, I'm still on 2014 and thought he needed PDF's... Quote Link to comment
