Sem Posted September 28, 2014 Share Posted September 28, 2014 I have the following problem, and it's quite complicated, so bare with me here. I have an 3d landscape modelled, and i want to scale it. But not evenly. I want the model to scale let's say 1:250 at one side and 1:500 at the other side. So that the model will have an exaterated perspective. Things would appear smaller in the back than they would in the front. Obviously everything in the model should scale with the two ends, so it would evolve graduately. If one would imagine the model with an box around it, i want the cubical bow to become tapered. But I cannot move the grips if I make a group. Any thoughts? Maybe different software? All help would be very much appreciated! VW 2014 Mac/Windows Quote Link to comment
CipesDesign Posted September 28, 2014 Share Posted September 28, 2014 It's perhaps possible to achieve what you're after by setting the perspective to the point and field of view as desired, however It's not clear from your question what view you're after (eg: top, Birdseye,etc.). The fastest way to experiment with this might be to use the Renderworks Camera. You can easily set the view from and view to positions and the distortion you want will be created by the amount of perspective. Quote Link to comment
Sem Posted September 29, 2014 Author Share Posted September 29, 2014 Thanks for your answer Peter, but it won't solve the problem. You see, I'm making a model in 3d to use to 3d print (or otherwise manufacture) a phisical model. This model should have the perspective distortion in a phisical way, a camera distortion wont help me there. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 29, 2014 Vectorworks, Inc Employee Share Posted September 29, 2014 Currently I know of no way to do this this kind of controlled asymmetric scaling to a 3D object in Vectorworks. I have seen this in other applications, I THINK one of those was Blender, which is free and worth a look: http://www.blender.org/download/ To go from Vectorworks to Blender, I would recommend exporting 3DS or STL. Quote Link to comment
bcd Posted September 29, 2014 Share Posted September 29, 2014 (edited) VW2015 will do this for you: Create a Drape Surface of the Site Model Create a vertical reference plane object Deform Tool>Taper Solid mode Select the Nurbs Surface Set the Taper Center to the center of the reference object Define the Reference distance & the taper ratio with another couple of clicks. Edited September 29, 2014 by bcd Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 29, 2014 Vectorworks, Inc Employee Share Posted September 29, 2014 With the drape! Nice! I had tried it with the site model directly and got no joy. Thank you bcd! Quote Link to comment
CipesDesign Posted September 29, 2014 Share Posted September 29, 2014 Yeah that's very cool!! Quote Link to comment
bcd Posted September 29, 2014 Share Posted September 29, 2014 Thanks - gotta love 2015! Quote Link to comment
Sem Posted October 2, 2014 Author Share Posted October 2, 2014 Wow, that helped me alot bcd! I'm currently running VW 2014, so im goint to see if it works with that, or else I'll upgrade. Thanks so far. Quote Link to comment
Sem Posted October 3, 2014 Author Share Posted October 3, 2014 [font:Arial]The VW2015 does the trick perfectly. But do you guys know why an angled line becomes rounded in the command? Is there any way to prefom the command without the rounding? [/font] Quote Link to comment
Sem Posted October 9, 2014 Author Share Posted October 9, 2014 Do you know if it's also possible to execute this command in 3 dimensions? So that not just the x and y axis move, but also the z axis. In the case of your drape surface i want the reference plane to move towards the end of the model aswell, and scale accordingly. Quote Link to comment
bcd Posted October 9, 2014 Share Posted October 9, 2014 Try rotating the reference plane 90º and performing a second distortion in the z Quote Link to comment
