Keynotes- some changing to N/A when re-sizing
  • 2 weeks later...
I've had some similar problems and was able to fix by using Text>Reconcile Notes. Sometimes callouts on one sheet become connected to a legend on another sheet, causing some mysterious behavior.
When you use the callout tool, check the Callout Tool Preferences and make sure "Default Legend" is selected instead of the legend for your current sheet.
