mentalenergy Posted January 10, 2003 Share Posted January 10, 2003 Hi Im using VW Arch w/RW 9.5.2. Im able to export to the various formats available in the export menu, but when selecting the image export option nothing happens! No 'thinking' sounds, nothing, as if i didnt click on anything. What did i stupidly delete!? Quote Link to comment
Guest Posted January 10, 2003 Share Posted January 10, 2003 Make sure you have QuickTime installed. We use QuickTime to generate the various image file formats for us. Quote Link to comment
Guest Posted January 10, 2003 Share Posted January 10, 2003 If QuickTime isn't installed, you should get an error message when launching VW 8-10. The problem is that you are using QT 5 or 6 and installed it using a typical install. You should go back to your QT 5 install. When installing it, make sure you select a CUSTOM install rather than the default Typical install. The following dialog box will give you a list of items you wish to install. Click on the Select All button to select all components. When the install is complete, restart the computer and then launch VW. You should now be able to export images in VW> If you are installing QT 6 -- please update to VW 9.5.3 to avoid a number of placement of images problems on export. Quote Link to comment
