gmm18 0 Posted September 18, 2014 Not working, normally hold space bar and you can pan, release space bar and you would go back to the tool you were using. This is referred to as boomerang But now in 2015 hitting the space bar it goes to boomerang for a split second, and even though still holding space bar it reverts instantly back to the original tool mode... Any fixes? Quote Share this post Link to post
PVA - Jim 2,383 Posted September 18, 2014 What version of Mac OS X are you on? 10.6? Quote Share this post Link to post
gmm18 0 Posted September 18, 2014 VW2015 does not work on 10.6 at all. I am on OSX 10.9.4, I will update my signature. Quote Share this post Link to post
PVA - Jim 2,383 Posted September 18, 2014 VW2015 does not work on 10.6 at all. (I am aware, I was checking just to be sure because of that.) Do any other modifier hotkeys behave that way for you as well? Holding down Option to duplicate for instance, not staying in the duplicate mode? Or the B key for xray mode not staying on when held down? Quote Share this post Link to post
gmm18 0 Posted September 18, 2014 Interesting. The Option key duplicate is fine, but the B Xray is not sticking when held down. I will restart and see. Quote Share this post Link to post
PVA - Jim 2,383 Posted September 18, 2014 If it keeps doing that after a reboot, perform this procedure with Vectorworks and all other applications closed: http://kbase.vectorworks.net/questions/623/Disk+Utility Then, launch just Vectorworks 2015 and try the hotkeys again. Quote Share this post Link to post
gmm18 0 Posted September 18, 2014 Ran disk utility and it is still not holding. (both for boomerang pan and for X-ray) Quote Share this post Link to post
CipesDesign 148 Posted September 18, 2014 This problem is caused by Safari. I'm not sure why or how, but if you quit Safari the problem will be fixed. You can then restart Safari. It can (and will) recur. So you follow the same procedure: quit and restart Safari. Quote Share this post Link to post
PVA - Jim 2,383 Posted September 18, 2014 I have seen it caused by Office for Mac as well. The issue still occurred with no other apps running, including Safari? Quote Share this post Link to post
CipesDesign 148 Posted September 18, 2014 Well Jim, using Office for Mac should always be suspect ;-) [humor] Quote Share this post Link to post
PVA - Jim 2,383 Posted September 18, 2014 Well Jim, using Office for Mac should always be suspect ;-) [humor] That's a FACT. Quote Share this post Link to post
gmm18 0 Posted September 18, 2014 Quitting Safari alone did not work, needed to restart computer, but it is all working now. So no big deal, just a minor booger. Quote Share this post Link to post
willofmaine 130 Posted February 8, 2017 On 9/18/2014 at 3:06 PM, CipesDesign said: This problem is caused by Safari. I'm not sure why or how, but if you quit Safari the problem will be fixed. You can then restart Safari. It can (and will) recur. So you follow the same procedure: quit and restart Safari. Wow, holy mackerel, that actually worked! Thanks Peter! Never would have figured that one out... Quote Share this post Link to post
kob 5 Posted December 1, 2017 I've just noticed this happening with VW 2018. I found this thread, and indeed, quitting Safari cleared it up. I thought I'd mention it here in case anyone else was experiencing the same thing. Quote Share this post Link to post
