VW 2015 Curtain Walls
J Lucas
Jim: Is there a way to create curtain wall/store front walls that include operable doors and windows? So far there has been no tool in VW that will do this. (I have my own workaround, but it is cumbersome.) I was hoping that the Curtain Wall tool would address this, but given that it is now integrated with the wall tool, that looks unlikely.
Edited by J Lucas
You can also use the Edit Curtain Wall tool and choose edit panels from the toolbar. Then select a panel and use the context menu. There will be two options to insert a door or window directly into the selected panel. This will save the step of having to check the Curtain Wall object setting.
Edited by Judah Warshaw
