John Whyte Posted September 18, 2014 Share Posted September 18, 2014 Ive got an image of a bath i need to model for a setting out drawing, please see below Ordinarily i would draw a hemisphere, using the 3d tools group it and then stretch the group, but this would leave me with an Easter egg shape ie. symmetrical shape, how would i model a shape like this that is tear drop shaped, ie. narrower at one end than the other ? Quote Link to comment
Bart Rammeloo Posted September 18, 2014 Share Posted September 18, 2014 I would try this with Model > 3D Powerpack > Revolve with rail. - you draw the top path (ellipse?) - you draw the axis (in side view: off center) - from path to axis, in a side view, you draw the section Then you use the command. You could combine this with Shell solid to give it a thickness, and then cut or add parts, fillet edges and so on, depending on your preferred workflow. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 18, 2014 Vectorworks, Inc Employee Share Posted September 18, 2014 There are quite a few ways. The above will work great, you can also create a half-profile and use the Model > Sweep command, sweeping 180 degrees, then Shell as mentioned above to give the needed thickness. A rough example: [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=11115&filename=sweep.PNG[/img] [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=11116&filename=sweep2.PNG[/img] Quote Link to comment
VincentCuclair Posted September 18, 2014 Share Posted September 18, 2014 (edited) If you have a make and model search Google Warehouse first.......if you can't find that, my bet would be Jims Sweep Command, however i would draw a section of the bath as a polygon/polyline and sweep this, that way the inside and outside of the bath lining can have different shaped curves, plus you can easily edit the initial shape if it needs tweaking..... Edited September 18, 2014 by Vincent C Quote Link to comment
Bas Vellekoop Posted September 23, 2014 Share Posted September 23, 2014 Hi Jim, Can get the same shape, wondering what im doing wrong...? Can you post your file of the bath so i can see? Thanks Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 23, 2014 Vectorworks, Inc Employee Share Posted September 23, 2014 I didn't have the original still, mocked up a similar demo: Quote Link to comment
Bas Vellekoop Posted September 23, 2014 Share Posted September 23, 2014 Thanks! No i want to surface array the outside of the bath. How get i 1 nurbs surface so i can use that as a base surface? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 23, 2014 Vectorworks, Inc Employee Share Posted September 23, 2014 You can use the Extract tool in Extract Face mode on the outside, that will give you NURBS surfaces. It may need to be ungrouped right after the extract operation, it groups the results. Make sure "Select Tangent Entities" is selected in the Extract options if you click on the face and only get a small portion of it highlighted in red at first. Quote Link to comment
Bas Vellekoop Posted September 23, 2014 Share Posted September 23, 2014 (edited) Then you get group of 3 nurbs surfaces. I never succeeded to create 1 nurbs surface out of separate ones. Compose never worked and the combine tool I never got too do what I wanted. But today I got it too work - render mode: open gl (in wireframe its not possible because you cant select the sides that are lying on each other) - select combine tool - select dual object combine mode - select faces to combine - use tangency matching mode - result 1 nurbs surface Im happy! Edited September 23, 2014 by Buzz Lightyear Quote Link to comment
John Whyte Posted September 30, 2014 Author Share Posted September 30, 2014 @Vincent The only issue ive found with the Google Warehouse is that they usually dont import well into vectorworks and remain editable, not to mention being very heavy compared to a vwx drawn item Quote Link to comment
mike m oz Posted September 30, 2014 Share Posted September 30, 2014 A useful way around that problem John is to import the object into a blank file and then replace the parts with Vw equivalents. Quote Link to comment
