First steps with Python
DomC
Hello
I wanted to port some of my Document-Based Pascal Scripts to Python. Not because it ist necessary, just to learn something.
I tried just to build a Python example with some commands from the Vectorworks Namespace.
def Test():
   Text = 'Hello Vectorworks.'
   vs.AlrtDialog( Text+' This should work, or not?')
   vs.moveto(0,0)
   vs.Lineto(0,500)
Test()
The "AlrtDialog" seems to work. vs.moveto and vs.lineto do not want
Many thanks for some ideas!
Dom
Error Message:
Traceback (most recent call last):
File "", line 7, in
File "", line 5, in in Test
AttributeError: 'module' object has no attribute 'moveto'
Edited by DomC
Guest Jim Kelly
It's a case sensitivity thing - notice that you have "moveto" as the method name and not "MoveTo" and "Lineto" and not "LineTo".
Just ensure the case matches up here:
http://developer.vectorworks.net/index.php/VS:Function_Reference
You can also use the information at the bottom of here:
http://developer.vectorworks.net/index.php/Python
to use an IDE when developing that will autocomplete for you and/or do linting to tell you if a method doesn't exist.
Wow, a stupid alpha error.
(vectorscript is not case-sensitive)
Thank you so much!
Just to complete, the running code:
import vs
def Test():
vs.MoveTo(0,0)
vs.LineTo(0,500)
Test()
Guest Jim Kelly
Oh wow, actually that brings me back now that you mention it, because Pascal was my second programming language, and I guess now that you mention it, yes it wasn't case sensitive. Blast from the past. :)
