1. Success - Draw a polyline with a handful of vertices, closed, open, doesn't matter. Dbl click to enter reshape. Marquee around several vertices and drag to move them. Normal behavior.
2. Success - Same poly as above. Convert to NURBS. Try the marquee move of several vertices. Works fine.
3. Success - Draw two open polys, coincident at one or both ends. Compose to form single poly. Reshape with marquee of several vertices. Works fine.
4. Fail - Select poly from #3, Convert to NURBS. Try the marquee reshape. Marquee does not display. Only single vertex can move with Reshape. Screen/Layer status of source polys does not affect.
Benson Shaw
Can anyone confirm please:
I only tried this in v2014
-B
4 answers to this question
