scheven_architect Posted August 1, 2014 Share Posted August 1, 2014 (edited) A slab is defined by the contours of a wall, it would be great that when you move a wall, the slab adjusts accordingly... Edited August 1, 2014 by scheven_architect Quote Link to comment
0 willofmaine Posted August 1, 2014 Share Posted August 1, 2014 Doesn't it? In the OIP, select "Bounding" > "Pick Boundary..."; select the walls that should define the slab's boundary, then click the green checkmark in the menu bar. Use the selection tool to move one of the walls (make sure "Connected Walls Mode" is on) and the slab should automatically follow the moved wall... Quote Link to comment
scheven_architect
Edited by scheven_architectLink to comment
1 answer to this question
