Dan Kessler 1 Posted December 23, 2002 I'm fighting with the palette docking feature only available in the Windows version of VectorWorks 10. I can't seem to be able to have two palettes docked above and below each other. For example, I have a 2-columned palette docked correctly on the left side of the screen. There's plenty of room for another 2-column palette below it, but when I try to put one there, it always docks to the right of it. I can't move it below the other one. Am I doing something wrong? Is there a "modifier" key or something I need to hold when docking another palette? On a related note, it kind of seems like the Windows tool buttons have extra space around them that the Mac tools don't. In other words, the same palette in VW for Windows 2000 takes up more room on-screen than VW for Mac OS X. Is it just because Windows is a clunkier operating system, or was VW engineered that way? Dan [ 12-23-2002, 06:04 PM: Message edited by: dkessler ] Quote Share this post Link to post
P Retondo 111 Posted December 27, 2002 I've experienced a similar problem. Oddly, after docking and re-docking, using different orders of insertion, I was once able to get all of my toolbars into two columns on the left. Don't know what magic made that happen. You can minimize the problem by making your 2-column tool palettes into a single-column by using the mouse/resize cursor. Then, when side-by-side, they will occupy some of that unused space below. NNA: this appears to be a bug of some kind. WinXP VW 10.0.1 P4 2.2G, 768MB RAM [ 12-27-2002, 04:20 PM: Message edited by: P Retondo ] Quote Share this post Link to post
Dan Kessler 1 Posted December 30, 2002 P, Thanks for the reply. I'm glad it's not just me. NNA, please respond to whether or not this is a bug, and/or how to work around it. Thanks, Dan Quote Share this post Link to post
Mickey 37 Posted January 2, 2003 I have yet to move to VW10, but the best way to avoid these problems is by getting those pesky palletes off your drawing surface and onto a second monitor. Dual monitors is the only way to draft. -Mickey Quote Share this post Link to post
jnr 127 Posted January 2, 2003 I'm having the same problem and I have dual monitors. To boot, the attributes palette enlarges once docked, so it takes up more room than if it is not docked. I don't remember this being a problem in 9 Quote Share this post Link to post
Dan Kessler 1 Posted January 2, 2003 JNR, Man, you're not kiddin'. Once docked on the right side of my screen, the attributes palette looks ridiculous! It's big enough to be read from 20 feet away. I've had to resort to disabling palette docking, but that leads to other issues with the workspace. What's the deal NNA? Aren't you going to respond to this issue? It's OK to admit that this is a problem, you know. Quote Share this post Link to post
Sean Flaherty 0 Posted January 7, 2003 One tip: you can disable the docking for any single palette by holding down the control key when moving a palette. Quote Share this post Link to post
Guest Posted January 7, 2003 We are aware of the problems associated with palette docking. The engineers are currently looking into the issue. Currently there is no fix available. Quote Share this post Link to post
Peter N 0 Posted February 5, 2003 quote: Originally posted by Katie: We are aware of the problems associated with palette docking. The engineers are currently looking into the issue. Currently there is no fix available. Any update to the palette docking problem? thanks in advance. Peter Quote Share this post Link to post
Radio J 0 Posted February 9, 2003 Don't know if this help but I have noticed stability problems with Nvidia Detonator drivers in VW 10 with a Quadro 4 750 xgl, maybe other cards as well.Revision 30.82 seems pretty stable but still has the docking problems.ATI Catalyst 3.0 has no docking problems at all(that I've noticed) With a Radeon 9700 Pro.Hope that helps. Quote Share this post Link to post
