Ian Graham
de select v 2014 at end of files
Hello
I recently upgraded from VW2014 to VW2014 Architect. When I save the file form 2010 , it adds the v2014 at end of file, not overriding the file , but now a copy with new file name. How can i control this , so it does;t add the v2014 at end and overwrites my existing file, so I only have one file ?
Thanks
Ian
Once you open that file in 2014, use File > Save As, then you can select the original file to save over.
If you want to do that to all your files all at once, you can use Batch Converts "Convert in Place" mode. However I recommend keeping backups if you are going to upgrade past that many versions at once.
Batch Convert:
http://kbase.vectorworks.net/questions/784/Batch+Conversion+of+older+Vectorworks+files
