Diamond
DWG Export Viewport - Convert to 2D in Model Space
Hi,
I wondered if anyone can assist. I had thought in older versions of Vw, when Vw used to export a DWG into Model Space that all of the contents of the SLVP was converted into a truncated group of line work. It appears now that the SLVP creates a reference with a crop object that, when exploded, shows the whole contents of a the referenced design layer. When we issue DWG's, third parties explode these VP's and get a mess of line work instead of being able to edit a single detail in isolation.
Has anyone found a way around this? Thanks.
2 answers to this question
Crickets...
The resounded silence is deafening! I guess that is because it doesn't work the way I want it to. A wish list request then.
hi Diamond,
you can export the sheetlayer to modelspace but it will not export custom classproperties overides of the viewport. Use the "export viewport as 2d-graphic" are something (I work with the dutch version)
I also have problems with the dwg export and made the following post:
Forums » Feedback Center » Wish List Requests » dwg export sheet layer with custom class properties
