towertek1 Posted December 20, 2002 Share Posted December 20, 2002 Can someone explain to me how to adjust the precision for dimensions & set is a default? I looked through every option I can think of, from the units properties to the document properties & I have been unable to find anything that will allow me to change the default Dimension Precision from 1/8 to anything else. Any help would be appreciated. Thanks Quote Link to comment
Guest Posted December 20, 2002 Share Posted December 20, 2002 Go to the Page menu and select Units. Set Units for drop down box allows you to set the units for General Display, Primary Dimensions and secondary dimensions. If you want your dimensions to read to 1/64th place value, make sure the General Display is set to at least that as well. Please note -- these units will only be used on new objects. If you have dimensions already in the drawing that are not using the correct unit, you will need to redraw those dimensions. Quote Link to comment
Vectorworks, Inc Employee Mark Farnan Posted December 24, 2002 Vectorworks, Inc Employee Share Posted December 24, 2002 Selecting all of the previously created dimensions using the Custom Selection command and changing to the new precision on the Object Info palette also works. Quote Link to comment
