Join lines inside PIO
Pi_
Hi,
I want to join lines inside a PIO (the lines are a result of 'GetObjectHiddenLine').
The lines are in a group, I can select them but I cannot join them (DoMenuTextByName('Compose',0);)
The command works in a script but not inside a PIO. I tried ungrouping the group, entering the group (FinGroup),...
the selected items seem to be the lines+PIO itself,
Nextobj after FSobject gives nil (first selected object is PIO itself).
thanks Miguel,
I was looking for one command to join all lines in group, I ended up making an array of points:
>>take first line end point
>>loop trough all ellements in the group
>>check begin and endpoints
>>if beginpoint matches add endpoint to array and vice versa and delete element
>>loop again from beginning with new endpoint
>>draw polyline with array of points...
a lot of work, it works , but 'join(handle1,handle2)' would be so much easier...
Piet,
The following code will let you select 2 lines and will join them similar to the way is done with the Join menu command.
The Join procedure is the same format that you suggested:
PROCEDURE JoinLines;
VAR
line1Hdl,line2Hdl: HANDLE;
selPt: POINT3D;
FUNCTION CheckObjCallback(h : HANDLE; px, py : REAL) : BOOLEAN;
BEGIN
IF GetType(h) = 2 THEN
	CheckObjCallback:= TRUE
ELSE
	CheckObjCallback:= FALSE;
END;
PROCEDURE Join(VAR line1,line2: HANDLE);
VAR
	dist1,dist2: REAL;
	parallel, intOnLines : BOOLEAN;
	ln1beg,ln1end,ln2beg,ln2end,intPt: POINT;
BEGIN
GetSegPt1(line1,ln1beg.x,ln1beg.y);
GetSegPt2(line1,ln1end.x,ln1end.y);
GetSegPt1(line2,ln2beg.x,ln2beg.y);
GetSegPt2(line2,ln2end.x,ln2end.y);
LineLineIntersection(ln1beg,ln1end,ln2beg,ln2end,parallel,intOnLines,intPt);
dist1:= Distance(ln1beg.x,ln1beg.y,intPt.x,intPt.y);
dist2:= Distance(ln1end.x,ln1end.y,intPt.x,intPt.y);
IF dist1 > dist2 THEN
	SetSegPt2(line1,intPt.x,intPt.y)
ELSE
	SetSegPt1(line1,intPt.x,intPt.y);
dist1:= Distance(ln2beg.x,ln2beg.y,intPt.x,intPt.y);
dist2:= Distance(ln2end.x,ln2end.y,intPt.x,intPt.y);
	SetSegPt2(line2,intPt.x,intPt.y)
ELSE
	SetSegPt1(line2,intPt.x,intPt.y);
END;
BEGIN
TrackObject(CheckObjCallback, line1Hdl, selPt.x, selPt.y, selPt.z);
IF line1Hdl <> NIL THEN
BEGIN
SetSelect(line1Hdl);
TrackObject(CheckObjCallback, line2Hdl, selPt.x, selPt.y, selPt.z);
IF line2Hdl <> NIL THEN
	BEGIN
	SetSelect(line2Hdl);
	Join(line1Hdl,line2Hdl);
	END;
END;
END;
Run(JoinLines);
